Shopping cart  Shopping cart
0 Product(s) in cart
Total $0.00
» Checkout
Login Status  Login Status
Not logged in
» Login
Home » Hardware » Motor Couplers
 Checkout
Product ID: aero-coupler
AeroMarine collet style couplers
  (Enlarge)
Aeromarine collet style coupler.
This made in the USA is a top quality coupler that will grip cable tighter than another else on the market. The brass insert is replaceable and can be changed for other sizes if needed.
Options Available:
5mm - .072, 5mm smooth hole motor side to .072 piano wire.
5mm - .150, 5mm smooth hole motor side to .150 flex cable.
5mm - .187, 5mm smooth hole motor side to .187 flex cable.
6mm - .150, 5mm smooth hole motor side to .150 flex cable.
6mm - .187, 5mm smooth hole motor side to .187 flex cable.
8mm - .187, 8mm smooth hole motor side to .187 flex cable.
8mm - .250, 8mm smooth hole motor side to .250 flex cable.
Specs:
Weight: 1 ounce. Length: Approx 32.5mm(1.30") long x 16mm (.63") wide.
Price: $15.95
Add to cart
« Previous | Next »
Policy | Contact Us | About Us | Forums | Sitemap
