We Accept PayPal!
We ship to Worldwide* Click here for more info.
Not logged in
Home » RC Radios » Remote Control Systems
So you want to be free of the pains of running a Receiver (RX) battery pack? Tired of having a dead receiver pack ruin your day? Tired of buying AA batteries to power your receiver? Need to shed some weight from your Fast Electric? If you answered yes to any of those 3 questions this BEC (battery eliminator circuit) product is for you. It uses your motor battery pack to supply power to your receiver. At only 13 grams and 1.0" long this will fit almost anywhere! The Sport BEC powers your receiver and servos much more efficiently than a standard BEC. As many as 8 servos can be powered without worrying about an overheating the BEC circuit of your ESC. SportBEC works great up to very high voltages. SportBEC's output is selectable between 5V/6V using a small slide switch. The 6V setting gives more speed and torque to the servos. A red LED indicates when 6V is selected. Many design hours were spent on SportBEC to ensure it does not create radio interference. It uses a shielded inductor and optimized layout, so you can use it without fear of glitching. SportBEC installs between your ESC and receiver, so you don't have to modify your speed control to disable its internal BEC. Specs: Input voltage: 9V to 33.6v (3s-8s lithium, up to 21 NiMHs) Output current: 3.5A (~8 standard servos, 4-6 digital) Weight: 13g/.46oz (including wires) Universal connector fits all receivers. This is a Battery Eliminator Circuit Only. Not a Motor Speed Control. Additional notes: If you are using small servos make sure they can run at 6v. Some sub-micros, notably the Hitec HS-50 and Futaba S3154, can be damaged by a 6v supply. For best results, ensure that the SportBEC is installed at least 2 inches away from your receiver and antenna.
Email Friend
« Previous | Next »
