Shopping cart  Shopping cart
0 Product(s) in cart
Total $0.00
» Checkout
Login Status  Login Status
Not logged in
» Login
Home » RTR Upgrades » AquaCraft SuperVee 27R
 Checkout
Product ID: dh-AQUB23
AquaCraft SuperVee 27R Brushless FE 2.4GHz RTR Boat
  (Enlarge)
This boat replaces the SuperVee 27. New is an upgraded 1800kv motor and now includes two turn fins for left and right turning.
The AquaCraft SuperVee 27R includes many GrimRacer accessories such as Machined Aluminum Surface Drive Strut Assembly, Adjustable Anodized Rudder, Stainless Steel Trim Tab Plates, Aluminum Adjustable Turn Fin Assembly, Stainless Steel and Spring Steel Cowl Lock System. With speeds in the 30-35mph range, this is the first mass-produced RTR electric boat of its kind! This is not a toy!
New for 2010, The AquaCraft SuperVee 27R Racing Boat.
FEATURES:
Painted fiberglass Hull
Motor: Water cooled 6-pole 1800kV brushless.
Water cooled Motor
Radio: Tactic TTX240 2.4GHz with Secure Link Technology that prevents receiver from recognizing stray transmitter signals.
Electronic Speed Control: 45A with water cooling.
Drive System: .150 flex drive cable with Teflon cable guide.
Propeller: 40mm Fiber Reinforced Plastic (FRP)
Turn Fins: GrimRacer black anodized aluminum
Rudder: GrimRacer black anodized aluminum
Trim Tabs: GrimRacer stainless steel.
Pre-installed velcro straps for batteries.
Tow hook for easier retrieval.
Warranty: 90 day limited through Hobby Services beginning at date of purchase.
INCLUDES:
AquaCraft SuperVee 27R Racing Boat with motor, ESC, radio system, plywood stand, propeller, decals and instruction manual.
REQUIRES:
Motor Batteries: Two 7.2V 6-cell flat NiMH with Deans Ultra connector.
AA Batteries: Four for transmitter, FUGP7300
Battery Charger: Compatible with selected battery type
NOTE, if using LiPo batteries there is no Low Voltage cutoff built into the included esc. You would need to install a external Low Voltage Cutoff like the Product ID: de-liposhld-32. Or install a AquaCraft 60A Marine LiPo Ready ESC (AQUM7011).
SPECS:
Hull Length: 27" (686mm)
Overall Length: 31" (790mm)
Width: 8.13" (205mm)
Height: 5.5" (140mm)
Empty Weight: 53oz (1.5kg)
RTR Weight: 84oz (2.4kg)
List Price: $499.99
Price: $269.99
Notify when back in stock
« Previous | Next »
Policy | Contact Us | About Us | Forums | Sitemap
