Sale while supplies last! $59.99
This is the New Eagle Tree USB Micro Power V3 E-Logger with Deans Compatible connectors. If your looking for the optimum prop for your boat or gearing for your car, than this is the product for you. With this logger will be able to graph(computer required) voltage and amperage curves! The new v3 supports the optional gps sensor, so you can now tell the speeds of your model.
Logs pack current to 100amps and voltage
to 70 volts.
Eagle Tree continues to innovate in data collection with the eLogger V3. In addition to greatly enhanced resolution and accuracy, the V3 now supports voltage to 70 volts, current to 100 amps (150 amps optional), GPS (with optional GPS Expander), 4x the logging capacity of the V2, Three Temperatures, and Throttle Logging (or logging of two RPMs)!
Here are the key features of the MicroPower:
NEW: Logs pack current to +/- 100 amps (150 amps optional) and voltage from about 4.5 volts to 70 volts.
Each unit is calibrated on a custom built calibration machine for the best accuracy.
NEW: The MicroPower V3 has 4x the memory capacity of the V2!
Current is measured with a true Hall Effects Sensor - NOT a resistance shunt which produces heat and sucks power from your system!
Great for bench monitoring of battery charging also!
NEW:Accepts optional inexpensive sensors for GPS, Temperature, RPM (brushless, magnetic or optical), Airspeed, Altitude, Servo Current, and more, available below
NEW:Logs Throttle Movement with optional Y-Cable
All data is logged to permanent memory, which retains the data even when the power is removed.
Software computes Wattage, mAH, etc. for complete e-flight data.
Fully Compatible with Windows Vista, 98SE, ME, Win2K and XP™
Integrated USB with included cable (NOT a USB to serial port cable like other loggers)
Weighs about 0.7 oz (20 grams). Version with Wire Leads weighs slightly more.
Supports USB Live Mode, which lets you see what's happening in the model LIVE on the bench, on your PC
Adjustable logging rate (1-10 samples/second) and lossless data compression for long log times
Comes with our state of the art Windows virtual playback display and graphing.
Powerful Graphing software has advanced charting features, such as amps vs volts.
Internet Updatable firmware - as we add new features or (heaven forbid) have a firmware bug, the update is just a download away! No need to ship hardware back and forth.
Full support for English and Metric units
The MicroPower system comes with everything you need to log current and voltage, right out of the box (logger, USB cable, CD, manual).
