We Accept PayPal!
We ship to Worldwide* Click here for more info.
Not logged in
Home » Motors » Brushless Motors
On Sale for $99.99 for a limited time only. If your a sport boater or top notch racer on a budget, the Feigao motor is the Brushless motor for you! Feigao high performance brushless motors have the rpm and motor efficiency similar to that of Brushless motors like Hacker that are 2 to 4 times higher in Price! The Feigao 580L motor replaces the KB45 motors we used to sell. The Feigao 580L motor is a far better motor. It runs cooler because its far more efficient and much better balanced. It also comes with a 6mm drive shaft that has a 5mm output shaft to fit all the popular 5mm couplers.
This 580L "Long" Sized Feigao Motor is 76 mm in Length. Click for Feigao 580 L Motor Chart
Motor Specs: 12-32 NiMh or 4s to 8s Lipo cells in a 30"- 40" mono or hydro. 1400 - 1800 Watts Maximum with proper cooling. 45mm Diameter x 76mm long 5mm Output Shaft for use with 5mm Couplers. 25mm Mounting Hole Spacing. Uses 3mm screws. 545 grams Recommended rpm range 25k - 35k RPM. 2-Pole Neo Magnets & Compressed Windings.
Email Friend
« Previous | Next »
These products are recommended with items in your cart.
