Shopping cart  Shopping cart
0 Product(s) in cart
Total $0.00
» Checkout
Login Status  Login Status
Not logged in
» Login
Home » Cooling System Parts » Motor Water Cooling
 Checkout
Product ID: ham-spartan
Traxxas Spartan Upgraded Cooling jacket
In Stock: 14
  (Enlarge)
Traxxas Spartan 36mm Motor.
This Aluminum water jacket is longer than the stock silicon jacket and uses larger inside passage ways for added water volume circulating around the motor. Which translates into better cooling. Both the water inlet and outlet are positioned at a 90 degree angle and pointed in opposite directions for optimal fit in the Traxxas Spartan.
As of 7/11/2011 these include adjustable directional water fittings.
Specs:
Measures 2.44"(62mm) long and 1.55"(39.3mm) Outside diameter.
Note: Fits both 1st and 2nd Generation Traxxas Spartan Motors, Also 3674 Leopard Motors.
For the 1st Gen Motor you will need a 1.5mm Allen Driver to remove the stock rear screws on the motor.
Price: $19.99
Add to cart
« Previous | Next »
Policy | Contact Us | About Us | Forums | Sitemap
