0 Product(s) in cart
Total $0.00
» Checkout
 Login Status
Not logged in
» Login
Home » Electronic Speed Controls » Brushless Speed Controls
 Checkout
Product ID: hef-sword-200lv
Swordfish 200 Amp ESC
In Stock: 0
Previous 1 of 3 (Enlarge) Next
Discontinued, replaced by Swordfish 200+ with data logging. Click her for Info
Hifei Swordfish 200 amp water cooled esc. This is a high quality ESC designed specifically for racing boat. Unique PCB layout allows the water cooling plate to cool both fet boards evenly. Programing can be done with your transmitter or optional program card, optional USB adapter or optional LCD Program Box/Handheld Unit.
6-20 NiCad/NiMh cells or 2s to 6s LiPo. This unit is water resistant.
As of 8/16/2011 these come with a second cooling plate.
Specs:
Microprocessor controlled
Extremely low resistance .00066 ohm
200A continuous
Up to 20cells NiMH/NiCad or 2 to 6cell Lithium-polymer
High rate adjustable switching (PWM:8KHz/12KHz/16KHz)
Built in Battery Eliminator Circuit(BEC) 3.5A
Programmable low voltage cutoff
Programmable cutoff types(soft cutoff/hard cutoff)
Programmable brake type(disable/soft brake/hard brake)
Time advance programmable (low/standard/high)
Supports Hifei Program Card  and/or USB Link
Programmable start up type(very soft start/soft start/fast start)
Thermal Protection(100 centigrade)
Safe “power on” arming program ensures motor will not accidentally turn on.
The ESC is disabled when the voltage is over 26v at power-on
10 Gauge Wire Battery end.
10 Gauge Wire on the motor end.
Measures: 110mm X 44mm X 24mm
Weights: 155gr
Requires:
8mm connectors on battery end.
5.5mm Bullet connectors on the motor end.
Click here to download zip folder with software, firmware and manuals as of 2012-01-03.
swordfish: Add a USB program adapter (pc required) (+$6.00)
Email Friend
Ask A Question
Price: $99.99
Notify when back in stock
« Previous | Next »
Policy | Contact Us | About Us | Forums | Sitemap
