0 Product(s) in cart
Total $0.00
» Checkout
 Login Status
Not logged in
» Login
Home » Electronic Speed Controls ESC » Brushless Speed Controls ESC
 Checkout
Product ID: ker-seaking-180
Hobby Wing SeaKing 180
In Stock: 0
  (Enlarge)
Discontinued - Replaced by the Seaking 180 v3 or Leopard Marine 180 v3
Click here for info.
This is boat model, specially designed for boat use with water-cooling system and the esc is water resistant.
  • Special designed for RC boat, with excellent start-up, acceleration and linearity features.
  • With 2 running modes ("Forward" mode and "Forward/Backward" mode).
  • Multiple protection features: Low voltage cut-off protection for lithium or nickel battery / Over-heat protection / Throttle signal loss protection.
  • With 8 steps of timing adjustment, compatible with all kinds of sensorless brushless motors.
  • Switching mode built-in BEC has a very powerful output even working with 6 cells lipo battery.
  • User programmable and compatible with the pocket-sized Digital LED Program Card (Optional equipment) to set the ESC easily.
    Hobby Wing has added a three capacitor bank for added circuitry protection.
Specs:
● Output: Continuous current 180A, burst current 360A.
● Input: 6-18 cells NiMH/NiCd or 2-6 cells LiPo.
● BEC Output: 5.8V@3A Switching mode built-in BEC.
● 10 gauge wire
● External diameter of the water cooling pipe: 5.0mm
● Size: 72mm(L) * 68mm(W) * 34mm(H).
● Weight: 165g
Requires:
Connectors for both the motor end and battery end.
We suggest OSE 5.5mm or OSE 8mm bullet connectors.
Add a Seaking program card: No program card
Add a Seaking Programing Card (+$9.95)
Price: $119.95
Notify when back in stock
« Previous | Next »
These products are recommended with items in your cart.
Product ID: ker-seaking-pcard
Programming Card for SeaKing ESC's
In Stock: 0
Price: $9.95
Policy | Contact Us | About Us | Forums | Sitemap
