Neu Motors 2230The Neu 2230 motor is built to order, they take approx 4 weeks to build. If you don't see the option you need please email us. Click for Neu Motor ChartStandard KV Options: 725KV, 485KV *Weight: 48 Ounces*Width: 58mm*Length: 118mmShaft Size: 8mm Shaft.Poles: 4 The picture is an example of a smooth case.
Requires:Mounting Screws and connectors.
If you don't see the motor wind listed you need or need special options, we can special order from the entire Neu Motors lineup. Contact us for more details.*Size and weight are dependent on the wind options and are only approximate.
