0 Product(s) in cart
Total $0.00
» Checkout
 Login Status
Not logged in
» Login
Home » Motor Mounts
 Checkout
Product ID: ose-80230
Adjustable Water Cooled Mount for 380 to 540 Size Motors
In Stock: 30
Previous 1 of 2 (Enlarge) Next
Adjustable water cooled motor mount for 380, 500, 540 sized motors with adjustable motor hole spacing from 19mm to 25mm.
Angle is adjustable to allow straight alignment with propeller cable.
The anodized aluminum mounting plate is water cooled for added insurance against over heating. This can come in handy with both inrunner and outrunner style brushless motors. Its especially useful in outrunner motors, that do not have water cooling fitted to the motor.
Fiberglass mounting stands have holes drilled in the bottom to allow epoxy to flow into them to make a supperior bond. This mount can fit a flat mounting area like a rigger or hydro, or a deep vee.
Applications:
Fits most 380, 540, 550, 600 motors.
Feigao & Nemesis 380, 540, Hacker B50, B50L & B50xl.
Aqua SuperVee motor.
Ammo 2300 Motor.
Fits most motors that use a 19mm to 25mm mounting hole spacing, as long as the motor mounting screw is not larger than 3mm.
Requires you to provide motor mounting screws.
Email Friend
Ask A Question
Price: $12.95
« Previous | Next »
Policy | Contact Us | About Us | Forums | Sitemap
