Futaba 3PRKA 3-Channel FHSS System
Free Shipping on this product.The 3PRKA is an outstanding value in basic 2.4GHz control, whether you're looking at it as an inexpensive start-up system or an economical upgrade for your RTR. It puts the interference-free dependability of Futaba FHSS (Frequency Hopping Spread Spectrum) technology at your fingertips with the speed and ease of one-button Easy Link⢠binding.
Features-Fail-Safe (Throttle).-70:30 throttle mode.-Channel 3 switch.-Low-battery warning.-R203GF 3-channel high-voltage FHSS receiver.-Trims & servo reversing (Steering, Throttle).-Dual Rates (Steering).-EPA (Throttle).-Built-in antenna.-Protective cover.
Includes- Futaba 3PRKA 3-Channel Transmitter, 3-Channel R203GF Receiver- Instruction Manual
REQUIREMENTS - (4) AA Batteries
SPECS (TRANSMITTER)- Transmitting Frequency: 2.4GHz band - Power Requirement: Four AA cells SPECS (RECEIVER)- R203GF Receiver, FUTL7603- Dimensions: 1.54 x 0.91 x 0.33" (39 x 26 x 10mm) - Weight: 0.28oz (8g) - Operating Voltage: 4.8 - 7.4V (shared with servo) - Battery Fail Safe Voltage: 3.8V* - Current Drain: 30mA at no signal *Battery fail safe voltage is set for 4-cell NiCd/NiMH battery. Battery F/S does not work properly when other type of battery is used - Antenna Length: 7.5" (190.5mm)
