I just shattered the hull on my BJ24 and now I want to build my first boat. I've narrowed it down to the Delta Force Explorer 36. I'm in love with the sleek look and smooth running I've seen on YouTube. Besides I believe a lot of my electronics are well suited to this hull. From what I've read the DFE 36 is not the best in the corners but great for speed runs. Considering that I am just sport running and I am concerned about blow-overs I think this is a good fit.
the set up I want to start with is a Raider 150a, Leo 4074 1800kv, 642-645 props and 5-6s. I may try 7 or 8s and a 4094 1400-1600kv down the road if it is stable enough. I understand the transom is narrow on this boat so an inline strut/ rudder is almost a must. I would love to run dual leopards but the extra cost and maintenance scars me.
I could use help on the following issues/ questions:
Is my motor/esc/ prop combo on the right track?
Can anyone recommend a YouTube instructional video on how to fiberglass renforce sponsons and the tunnel? I want to strengthen this boat out of the gate.
How do you mount everything? Do you drill the hull and just screw everything down? Or I bought a carbon fiber plate to put down on the tunnel where all the electronics go- should I screw into that?
I like running two cooling lines to the motor and esc. I am use to doing thru hull mounted water pickups. Are there any special tips for dealing with doing this on a fiberglass hull vs ABS?
Thanks in advance for assisting.
