iCharger 406 Duo capacity selection
  • jingalls007
    • 1015
    Is there a ?capacity? feature to input capacity?
    Thanks doodes!
  • Bp9145
    • Jan 2016
    • 1466
    Yes, there is. After you have entered the voltage, 1S - 6S, press the button tab/system which is the very top/middle of the half circle block of functions. It will then move to next set of functions which in your case the capacity. You will see it because every time you press tab/system it will move and highlight the next block of functions.
    • RaceMechaniX
      • Sep 2007
      • 2821
      In the 4010, 406 and 308 is not necessary to enter a capacity, but you do need to have the appropriate charge rate. On mine I usually leave the setting at 5A which can safely charge 3000-6000mAh size packs. If I charge a smaller pack I will adjust the current down or use a different preset.
      -Tyler
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • jingalls007
        • 1015
        Thanks guys!
