What happens to a motor's amp draw when you decrease the supplied voltage?
  • Technoid
    • Dec 2018
    • 3
    I'm confused about what happens to the amp draw of a DC boat motor if I change the voltage being supplied to it. If I decrease the voltage, does the amp draw *also* decrease (because the prop is spinning slower, thus putting less physical load on the motor), or does the amp draw *increase* (because P=I*V, and the boat and propeller aren't changing)? I can't seem to wrap my head around this, even though I know that P=I*V, V=I*R, and RPM = KV*Volts. Oh yeah, and Power (kW) = Torque (N.m) x Speed (RPM) / 9.5488.
    For example, this motor on Amazon has the following specs:
    KV(RPM/V): 2250KV
    Watts: 1800W
    Max Voltage: <22.2V
    Max Amps: 80A
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    That all makes sense: P=I*V, so 1800=80*22.2 (roughly). But if I want to run this motor off my 4S battery (14.8 volts), then how does this affect the current draw, and the ESC I will need to spec? I've been assuming that this motor would require an 80-amp ESC, but if I'm only supplying 14.8 volts... do I need a larger ESC, or can I get away with using a smaller one? And *how much* larger or smaller? I have no idea what happens to my current as I change the voltage in this context!
    - Technoid (Alex)
  • NativePaul
    Greased Weasel
    • 2761
    If you drop the voltage whilst keeping the same prop the current will drop too. Having sad that an 80A ESC isn't enough, you need at least a 120A and preferably more.
    • Speed3
      • Mar 2017
      • 371
      Like the above reply said once the prop is the same and you reduce voltage the current will also decrease.
      As for ESC with a 2250kv an 150 to 180 amp ESC should be suitable for 4s.
      I would like to point out, that it is very easy to pull 80amps on 4s with a 2250kv motor.
      You would need to use a x440 size or smaller prop with that motor on 4s or 14.8v.
