Fiber Glass and Epoxy or JB Weld ???
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    Please post your opinion....
    Robert
    Canada
  • Fruity
    • Jan 2009
    • 147
    Fibreglass
    I use Fibreglass for everything, it's heavier, but from my experence, nice and strong. I use chopped strand matt & resin. If I need a thicker glue, I use resin & talcum powder to thicken it, works a treat.
    Cheers....Tim.
    • NitroVal
      • Jun 2009
      • 423
      Whats the application? I use each for different tasks. If I have a big gap to fill, I use fiberglass. If I need some flexibility, I use JB Weld. JB Weld is more dense that fiberglass. I'd be curious to know which would have a stronger tensile strength though.
      The RTR Nightmare- Electric King of Shaves
      Now with 540s- 62mph
      New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
      • Arctic Fire
        • 84
        Tensile Fiberglass, shear JB weld...
        Pulling vs. Shearing. We might not be as interested in tensile as it is a longitudinal test. The forces that our boats are more likely to encounter come from impact, in which case shear is the more important factor. HOWEVER, Fiberglass retains flexibility which can help absorb the force, but thats a different thing all together.
        The JB would also have a lower yield strength, and would have a quick brittle failure. Fiberglass has a higher yield strength, allowing it to deform elastically and return to original state. (it bends)
        My thoughts would be Fiberglass for sectional work, JB for smaller "hole filling" or crack sealing.. elastic materials in cracks are not the answer
        • LiPo Power
          • May 2009
          • 3186
          What about motor mounting ( metal or wood ) or aluminum servo mount?
          Fiberglass or JB weld?
          I see on many of your pictures that both are beeing used and personally think fiberglass looks clean, very clean.
          It is visable on your pictures that many of you are using JB weld to install brass tube in the hull. Why not fiberglass for clean look?
          Robert
          Canada
          • properchopper
            • 6968
            Robert, I've used Quick Set JB for shaft and motor mounts. Made a little "dam" from square wood & it comes out quite clean looking. I've seen o-rings used for the stuffing shaft "dam" as well.
            • Jeepers
              • May 2007
              • 1973
              Epoxy and fiberglass is all that I use,
              I have had POOR results with JB Weld I don't know why, but every time I blew over a hull, something came loose in side. so I quit using it.
              • FloatDaBoat
                Bare Bones Fabricator
                • Sep 2009
                • 368
                Loctite 50 minute Marine Epoxy doesn’t require a ‘dam’ to be used as is the case with JB Weld. It’s very viscose, & pretty much stays where you put it, unless large quantities are used. It’s only downside is that it turns from gray to a sickly pea green color after being exposed to UV rays in sunlight. Here’s a Photo of it used in the fabrication of some water pick-ups I built. It also works great for joining a deck to a hull during construction.
                • LiPo Power
                  • May 2009
                  • 3186
                  ...that looks clean and strong....
                  Canada
                  • 1coopgt
                    • Feb 2019
                    • 413
                    Robert
                    For what?
                    • ray schrauwen
                      • 9471
                      Thread is 12 years old guys
                      Nortavlag Bulc
                      • 1coopgt
                        • Feb 2019
                        • 413
                        Damn I got sucked in .
