Bending a brass tube...
  • jlanders001
    • Nov 2011
    • 41
    Hello again. Is there anything I need to know about putting a slight bend in a brass flex cable stuffing tube with a teflon tube inside? I want to minimize any binding that may occur afterward. Any tricks or techniques?
    Thanks,
    JTL
    Been in RC for years. But have not tried all the types of boats.... YET!
  • Chilli
    • Jan 2008
    • 3070
    It's not hard to do as long as you go slow. Don't try to do the bend in one shot. Do it a couple degrees at a time and spread the curve of the bend. Don't do it all in the same spot. It's hard to bent the tube at the ends so make your bend toward the middle if possible and then cut the tube to the appropriate length. You may have read about annealing but I have never had to do that in a a dozen builds. By an extra tube or two in case you mess up.
    Have fun!!
    Mike Chirillo
    www.capitolrcmodelboats.com
    • SirBudman32
      • Aug 2011
      • 625
      fill it with salt or sand first to keep from kinking it, then wash it out really good.
      Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
      • wetsleeves
        • 41
        I normally anneal the tube by heating it up after I have put dry sand in it, but if its got a teflon liner inside then you wont be able to anneal it. Just take it slow like Nautiboyz said and try not to do it in one go.
        • jlanders001
          • Nov 2011
          • 41
          Sand! Thats the kind of stuff I needed to know about. The teflon tube will not come out. Not sure why. Got it on Ebay. I'll just warm it up a little bit with a heat gun.
          Thanks guys. You must be night owls if you are on the east coast. Its 1:42am right now.
          • wetsleeves
            • 41
            No, Im on the other side of the pond. Australia is were I call home.
            • T.S.Davis
              • 6220
              Don't heat it if you're trying to save the teflon. I heat gun wont get you there anyway. You need fire. I always anneal but you don't have to. It just makes bending easier. I use sugar and tape off each end until I get the shape I want.
              On high powered boats I've started doubling up the brass. Thanks Alan.
              Noisy person
              • AlanN
                • Mar 2008
                • 334
                You're welcome. And Merry Xmas!
                • T.S.Davis
                  • 6220
                  hehe Been there broke that sh**!
                  Merry Christmas Alan.
                  Noisy person
                  • JIM MARCUM
                    • Jun 2011
                    • 773
                    To get the teflon liner out, buy the next smaller size of brass tubing (it will fit inside the first one) & push the teflon liner out with it. I have had great results with Annealing the brass tubing about 2-3" along the area you want to bend. Annealing is done with a torch until the brass tubing starts to become flexable. Set it aside & let it cool naturally. The brass tubing should bend easily with your thumbs. Do it slowly a little at a time. Footnote: if you ever need to bend aluminum tubing, anneal it then quench it in cold water. JIM
                    JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
                    • wetsleeves
                      • 41
                      when annealing the tube get it hot in the area you want to bend it. once hot you can cool it of with water.
                      obviously with out the teflon liner.
                      • LarrysDrifter
                        Big Booty Daddy
                        • May 2010
                        • 3278
                        That is wrong. Heat the tube until red hot. Set aside to cool. Bend as needed. Heat tube again until red hot, THEN quench in cool water. Quenching in water makes the brass hard again. Dont quench the stuffing tube until after you have the bend you want.
                        • liteumup69
                          • May 2011
                          • 145
                          would a brake line bender work?
                          • LarrysDrifter
                            Big Booty Daddy
                            • May 2010
                            • 3278
                            If its annealed and filled with salt and the ends are capped off and if the bender is for the same size tubing you are working with.
                            • wetsleeves
                              • 41
                              You can cool it off with water as weve done it many times. If the brass way really thick then you wouldnt cool it of with water but stuffing tube you can. In plumbing we do it all the time.
