Looking for better quality body filler?
  • siberianhusky
    • Dec 2009
    • 2187
    I'm not a painter or body guy by any stretch, I've been using the same container of Bondo brand filler for a few years on rc projects. Time for a new batch and would like something better if it exists. Don't like the way the edges feather and in general would like something a little easier to sand.
    What should I be looking for at an actual auto supply shop instead of the hardware store?
    Or are they all pretty much the same?
    Mostly use it to fair the bottoms of new hulls.
  • Heaving Earth
    Banned
    • Jun 2012
    • 1877
    Look for glaze at an automotive paint supply. It's a filler that is much smoother than standard filler. Good for finish work
    • liteumup69
      • May 2011
      • 143
      Here's a few I use down at the shop with good successes, Rage Gold, U POL Lite, U POL fiberall Lite, the fiber all lite has choped glass in it, but it's smooth like peanut butter, it will feather out, water proof, and it's good for patching small holes/cracks as long as you prep the area first.
      Good luck.. Paul
      • Chilli
        • Jan 2008
        • 3070
        MARINE-TEX!!!! It's stong, bonds well and feathers nice.
        Mike Chirillo
        www.capitolrcmodelboats.com
        • siberianhusky
          • Dec 2009
          • 2187
          Thanks a lot, going to try out the marinetex. Will also probably use it replacing a galley on a sailboat this spring
          Cheers
          • capnswanny
            • Feb 2012
            • 817
            I like this for finish work...super easy sand in about 10 minutes, doesn't bleed through, bonds well.
            I get it at the local auto parts store (NAPA) for about $20.
            This is NOT a toy?!?
            • 785boats
              Wet Track Racing
              • Nov 2008
              • 3169
              The good old fashion Selly's 'Plastibond' is still one of the best & most workable fillers around in my opinion. Works for me. Water proof & doesn't shrink. Can be sanded, drilled, tapped.
              Discover the full range of high performance Selleys products. From adhesives to sealants and fillers, If it's Selleys it Works. Visit us today!
              • BakedMopar
                No Mo Slipah
                • Sep 2009
                • 1679
                I use rage.
                • siberianhusky
                  • Dec 2009
                  • 2187
                  LOL rage is what happens after the crash before the repairs!
                  No Marinetex locally so I'm going to check out the Evercoat line, I've found it locally!
                  I like the looks of that Icing but not sure about availability.
                  Thanks for the help guys, gotta get moving on blueprinting a new to me hull. Doesn't need much, just a skim coat and some sanding.
