Ok, I am relatively new to rc boating, but I have about 20 years experience maintaining and servicing my own IO 20 to 28 foot boats, all single or double V8's. I just don't like flex drives. They are 'sloppy' and, well, flexy. Sorry, but for me, flex just seems like an easy way out from using 'proper' u-joints, solid shafts, and gears.
In my first non-production fast electric rc boat I used a solid stainless shaft in a double layer brass tube and a Dumas dogbone coupler between the motor and the shaft. That has worked fine for me so far, but the dogbone spurs are wearing down. I tried the same set up in my second boat, but with a little more angle between the motor shaft and drive shaft, and the dogbone spurs broke off first time I gave it full throttle. So I am debating whether to give in to the standard in the game, to go with flex shaft, or to try a ProBoat U-joint system between the motor and solid shaft. I have read in this very forum that a solid shaft is more efficient than a flex shaft. The downside being less ability to adjust shaft angle. I have already installed a flex shaft from OSE, but I may pull it out before next water test. Any suggestions? Comments?
