Lipo Low Voltage Cutoff device
  • Tony
    • 413
    Hi guys, are any of you here using one of these devices with your esc? My ETTI 125 has BEC built in. But, i want to use a seperate rx pack, and an external low voltage cutoff device so i don't have to do internal programming with the esc. OSE doesn't have any. So, I found these, but not sure if its any good.
    Anything and Everything for electric flight, your electric superstore, Helicopter store
    Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
    Tony
  • AntronX
    • Jul 2008
    • 333
    I have not tried any of them, but i recently got this: http://www.schulze-elektronik-gmbh.com/LiPoDiM-e.htm
    I like it more over whole pack monitoring, because it monitors each cell's voltage. If one cell get too low, it throttles down regardless of other cells voltage. I got it here, but did not try it in my boat yet.
    • JimClark
      • 5907
      I have one of the Novaks for my car but have not installed it
      Jim
      Billy Graham
      • Meniscus
        Refuse the box exists!
        • Jul 2008
        • 3225
        Diegoboy has a Novak, maybe see if he has used it yet.
        • Meniscus
          • Jul 2008
          • 3225
          Antron, how much did that unit you use run you?
          • ghostofpf1
            • Jun 2008
            • 392
            I use these when necessary and they perform as advertised http://www.dimensionengineering.com/LipoShield.htm
            I see esprit is selling them..pick your poison....I have ordered from both shops with good results.
            HTH
            Ghost
            • AntronX
              • Jul 2008
              • 333
              I got it from some Canadian store for $70 if i remember correctly.
              • Tony
                • 413
                HTH
                Ghost
                How many Lipo cells are you running with this device?
                • 785boats
                  Wet Track Racing
                  • Nov 2008
                  • 3169
                  Hi Tony.
                  The Lipo Shield will handle up to 12s. I've only used mine on 3s & 4s.
                  As AntronX stated they measure the average of the whole pack. The cutoff value is set at 3.0V /cell.
                  They also make one that measures each cell & the cutoff value can be adjusted up to 3.5V/cell. For the extra few bucks it's the one I'd go for if I were buying another one. One problem. You may need an adaptor lead depending on your balance plugs on your cells.
                  They also have an optional thermal probe that can be attatched to your cells for thermal shutdown too.
                  Paul.
                  • Tony
                    • 413
                    Originally posted by 785boats
                    Hi Tony.
                    Paul.
                    Hi Paul
                    That other device looks pretty interesting. However, it may not be easy to hook up the lipos since i'm running series.
                    • Flying Scotsman
                      Fast Electric Adict!
                      • Jun 2007
                      • 5190
                      Originally posted by Tony
                      Hi Paul
                      Tony, I have emailed the company earlier today on that specific question. I will let you know the answer.
                      Douggie
                      • RiverRat
                        • Sep 2007
                        • 96
                        The lipo sheilds work great. KintecRacing has some that were reprogramed to 3.3v.
                        • Tony
                          • 413
                          [QUOTE=RiverRat;63933]The lipo sheilds work great. KintecRacing has some that were reprogramed to 3.3v.[/QUOT]
                          Has the brown wire that connects to the lipo been remove
                          • RiverRat
                            • Sep 2007
                            • 96
                            No.
                            With the cutoffs you have 2 wires one red and one brown. On the esc side of your connectors, Solder the red wire to the red Deans or bullet connector, solder the brown to the black Deans or bullet. Then plug the esc into the lipo sheild. Then plug the lipo sheild into the reciever.
                            • Tony
                              • 413
                              Originally posted by RiverRat
                              No.
                              Lipo Shield came yesterday. I'll test it out soon. Thanks for the infos guys.
