I am wanting to get feedback from people on different mathematic formulas that I have found over the years that help determine different aspects of Boats. Please chime in if you agree with the equations or if you think the formulas are somehow flawed.
#1 I once saw a formula that said an electric boat needs 150 watts of power per lb. I was corrected on that through one of these forums to say that number should be more like 230 watts per lb. A bit more research showed that a full scale (30', 6800lbs, 3000 hp) Unlimited hydroplane has a ratio of about 329 watts per lb and they achieve speeds of around 200 mph.
#2 To figure out the wattage my motor is putting out, I found the maximum wattage and the maximum voltage. I figured the percentage of voltage I was running based on battery cell count and resulting voltage. I divided the voltage being used by the maximum voltage to find what percentage of the maximum I was utilizing. Then I multiplied the decimal equivalent of the provided voltage by the max wattage of the motor to find out the amount of power I should expect the motor to put out.
#3 Speed is a formula of (Volts x kv of motor = rpm)(rpm x pitch of prop=inches per minute)( inches/min x 60= inches per hour)(Inches/hour %12 = feet per hour) (Feet/hour / 5280 = miles/hour) ( miles/hour x .8 (20% prop slip) =actual speed of boat.
#4 Amp draw (Watts / volts = amp draw)
Like I mentioned, I am actually looking for feedback on how reliable or accurate these formulas are. I am hoping that if you have feedback, that it is more than "no that is wrong", please feel free to add a different formula and explanation as to why one is right and the other wrong.
