Hi everybody,
I'd like to thread a 4mm. prop shaft in order to use 1/8" drive dog props (usually I use M4 props); it’s a custom made prop shaft as I should couple it with a 1,5 mm. spring wire and I cannot find this measure on the market.
Is there a specific 1/8" die to choose?
I found these:
ME die = Model Engineer die or Model Engineering dies in 40tpi = threads per inch --> http://www.tap-die.com/contents/en-u...tpi_40tpi.html
MTP die = MTP die = Model Taper Pipe dies or METP = Model Engineering Taper Pipe die dies in 56 tpi = threads per inch --> http://www.tap-die.com/contents/en-u..._MTP_dies.html
Which is the wright choice; first, second, none of them?
Many thanks
Cheers
Andrea
I found these:
Many thanks
Cheers
Andrea
