Not to be overlooked...
Recoil 26-inch Self-Righting Deep-V BL:RTR
Features
Capable of reaching speeds of 30+ mph
Self-righting hull system keeps you from going belly-up
Water-cooled 2100Kv brushless motor and 60-AMP Dynamite® ESC
11.1V 3200mAh 3S LiPo and LiPo balance charger included
Includes Pro Boat® 2.4Ghz marine radio system
Waterproof electronics
Injection molded radio tray
Aluminum rudder with stainless trim tabs
Stainless steel hardware
Flex shaft with Teflon liner
Composite molded 2 blade propeller
Specifications
Length:
26 in (660.4mm)
Beam:
7.9 in (200mm)
Motor Size:
2100Kv 14-Pole Brushless Outrunner Marine Motor, 33mm X 42mm
Weight:
3 LB (1.4 KG)
Speed:
30+ MPH
Radio:
2.4GHz 2-Channel Surface Transmiter
Speed Control:
60A BL Marine ESC 2-3S
Hull Material:
Blow Mold ABS
Trim Scheme Colors:
Yellow/Orange
Prop Size:
1.34 x 2.06
Hull Type:
Battery:
11.1V 3200mAh 3S 30C LiPo
Kit/RTR:
RTR
Drive System:
Flex Shaft
Is Assembly Required:
No
Features
Specifications
Length:
26 in (660.4mm)
Beam:
7.9 in (200mm)
Motor Size:
Weight:
3 LB (1.4 KG)
Speed:
30+ MPH
Radio:
Speed Control:
Hull Material:
Blow Mold ABS
Trim Scheme Colors:
Yellow/Orange
Prop Size:
1.34 x 2.06
Hull Type:
Battery:
Kit/RTR:
RTR
Drive System:
Flex Shaft
No
