Used Leopard 4082 X2 Motor with jacket. Marked 2000kv but rewound by Huff Racing for performance 2163kv. This motor cost about $200 when it was new.
Special while supplies last! FREE Water Jacket with Leopard 4082 X2 Motor Purchase! 40mm Diameter by 82mm Long Brushless Motor by Leopard Power. Hand wound for high efficiency of up to 90%. Comes with high-quality bearings and neodymium magnets for high power. Includes endbells that are assembled with screws for both strength and ease of maintenance. Specs: Magnets: neodymium Watts: 2400 with Over 3500 Burst. Poles: 4 Motor Shaft: 5mm with flat spot Can Measures: 40mm diameter x 82mm long Weight: 460 Grams Mounting screw diameter required: 3mm Mounting Holes 25mm apart for use with most 540 mounts. Includes Leopard 6.0mm male bullet plugs soldered to the motor and a matching set for your esc connection.
OSE Suggests 20,000-35,000 total rpm for boats. We suggest most Fast Electric Boaters should run in the 25,000RPM range for Sport Boating or 30,000RPM Range for racing. These are only guidelines, we suggest if you do not have the knowledge to pick the correct motor, please consult us first or other members of the rc fast electric boating community. Either at a local club or on our OSE Forums.
