This is the Castle 1717 1580KV Brushless Motor High-quality over-sized ABEC-1 bearings. Sintered Neodymium magnets. Superior electromagnetic design. Installed 6.5mm gold connectors with 10gauge wire. REQUIRES: (3) Castle 6.5mm Female Connectors. Specs: Maximum Input Volts: 25.2 (For Cars). OSE Recommends 4s-6s Lipo power for Boats. Amp Rating: 120Weight: oz (g) Motor Diameter: mm, mm with fins. Motor Length: Shaft: with flat spot.
The Castle 1717 1650KV motor is a 4-POLE 12-SLOT design that boasts exceptional EFFICIENCY and produces LESS HEAT. This motor is a blast from the past with the added benefit of sensored capabilities! It is the perfect upgrade for any 1/6th scale vehicles weighing up to 20 lbs and running up to 8s LiPo; it is also a great upgrade for drivers looking for a reliable, high torque 8s motor for their 1/8th scale vehicles.
Without a robust and reliable design, efficiency will only go so far. RC enthusiasts love pushing their equipment to the edge. The Castle engineers know this and spared no expense when developing a design that could hold up to the harsh conditions that the RC community will throw at it, resulting in a cooler running motor. A cooler motor has a longer lifetime. Construction of our motor required careful component selection; each verified through internal testing to ensure the HIGHEST EFFICIENCY possible. In the end, the result is a motor with unmatched quality, performance, and reliability. We wouldn’t put our name on anything less.
