ABC 10-50 Series 2 Blade Cleaver Propeller, 2.0" to 2.6"
Product ID abc-XXXX-10-50(2)CLL-2
Price: $24.95
ABC 2.0 Inch (50.8mm) to ABC 2.6 Inch (66.0mm) diameter props.
Fits 3/16"(4.75mm) Shafts.
Available in three different pitches
1.4, 1.6 or 1.8 Pitch Ratio
As pitch increases the blade angle increases.
How the ABC numbering system works.
XXXX-XX-XX(X) XXX
For example a 2014-10-50(2) CLL breaks down like this.
20 is the diameter in inches.
1.4 Pitch Radio
10-RAKE ANGLE
50-BLADE AREA RATIO
(2)-NUMBER OF BLADES
CL-CLEAVER OR CP-CHOPPER
L-LEFT ROTATION OR R-RIGHT ROTATION
NOTE:
Shaft Size 3/16" (4.75mm) from 2014 to 2418.
Shaft Size 1/4"   (6.35mm) from 2514 Series and larger prop diameters.
