ABC 10-50 Series Reversed 3 Blade Cleaver Propeller
Product ID abc-XXXX-10-50(3)CLR
Price: $29.95
ABC Cleaver Series Reversed 3 Blade Propeller, .50 Bar
We have these in sizes ranging from 1.5" (38mm) Diameter to 2.6" (66mm) Diameter.
These are .50 bar props, meaning they have less blade area than the .75 bar style ABC props.
 Attention! This prop is made for boats that require a clockwise spinning prop!
NUMBERING SYSTEM
XXXX-XX-XX(X) XXX
EXAMPLE:
 1516-10-50(3) CLR
1.5"(38.10mm) in diameter.
1.6 Pitch Radio
10-RAKE ANGLE
50-BLADE AREA RATIO
(3)-NUMBER OF BLADES
CL-CLEAVER OR CP-CHOPPER
 L-LEFT ROTATION OR R-RIGHT ROTATION
NOTE:
Shaft Size 3/16" (4.75mm) from 1516 to 2318.
Shaft Size 1/4"(6.35mm)from 2616 and larger prop diameters.
These also come in the opposite rotation for twin motor applications. See Product ID: abc-XXXX-10-50(3)CLL
ABC 10-50 Series 3 Blade Cleaver Propeller
Product ID abc-XXXX-10-50(3)CLL
Price$29.95
