ABC 17-45 Series Reversed 2 Blade Cleaver Propeller
Product ID abc-XXXX-17-45(2)CLR
Price: $29.99
ABC Cleaver Series 2 Blade Reversed Propellers, .45 Bar
1.6 Inch (40.6mm) to 1.9 Inch (48.2mm) diameter props.
Shaft Size 3/16" (4.75mm) from 1516 to 2016.
Shaft Size 1/4" (6.35mm) from 2114 and larger prop diameters.
Attention! This prop is made for boats that require a clockwise spinning prop!
As pitch increases the blade angle increases.
How the ABC numbering system works.
XXXX-XX-XX(X) XXX
For example an 1815-17-45(2) CLL breaks down like this.
1.8 is the diameter in inches.
1.5 Pitch Radio
17-RAKE ANGLE
45-BLADE AREA RATIO
(2)-NUMBER OF BLADES
CL-CLEAVER OR CP-CHOPPER
L-LEFT ROTATION OR R-RIGHT ROTATION
These also come in the opposite rotation for twin motor applications. See Product ID: abc-XXXX-17-45(2)CLL
« Previous | Next »
ABC 17-45 Series 2 Blade Cleaver Propeller
1 of 2
Product ID abc-XXXX-17-45(2)CLL
Price$29.99
