ABC 23-50 Series 3 Blade Cleaver Propeller
Product ID abc-XXXX-23-50(3)CLL
Price: $34.99
ABC Cleaver Series 3 Blade Propeller, .50 Bar
These are .50 bar props, meaning they have less blade area than the .75 bar style ABC props.
NUMBERING SYSTEM
XXXX-XX-XX(X) XXX
For example a 1817-23-50(3) CLL breaks down like this.
1.8 is the diameter in inches.
1.7 Pitch Radio
23-RAKE ANGLE
50-BLADE AREA RATIO
(3)-NUMBER OF BLADES
CL-CLEAVER OR CP-CHOPPER
L-LEFT ROTATION OR R-RIGHT ROTATION.
Shaft Size 3/16" (4.75mm)
Note: Due to the longer than nornal hub length (23mm), a longer prop shaft may be required.)
ABC 23-50 Series Reversed 3 Blade Cleaver Propeller
1 of 2
Product ID abc-XXXX-23-50(3)CLR
Price$34.99
