ABC SK Cleaver Series 2 Blade Propellers, .38 Bar 1.5 Inch (38.1mm) diameter props. Fits 3/16"(4.75mm) Shafts. Available in two different pitch ratiosAs pitch increases the blade angle increases.
How the ABC numbering system works.XXXX-XX-XX(X) XXX
Example an 1521-19-38(2) SKL breaks down like this. 15 = 1.5" diameter in inches. 21 = 2.1" Pitch Radio 19 = RAKE ANGLE 38 = BLADE AREA RATIO (Bar) (2) = NUMBER OF BLADES SK = CLEAVERL = LEFT ROTATION OR R-RIGHT ROTATION
Pick up where you left off.
