JB Kwik sets in 6 minutes and is fully hardened in 24 hours. This product has a shorter set time than JB Weld but a slightly lower bond rating. Much thicker than CA glues, this epoxy can be used to glue stuffing tubes, servo mounts, and other larger items that need strong bonding strength.
Quick six-minute set time lets you complete repairs without waiting around. Holds 2424 PSI
High tensile strength creates a permanent, reliable bond for tough fixes.
Drill And Sand It
You can easily shape, tap, file, sand, and drill it after it has cured.
Withstands 300 Degrees
Formulated to handle high-temperature environments up to 300°F.
Easy 1:1 Mixing
The simple equal-parts mixing ratio ensures a perfect blend every time. Includes: (2) 5 oz tubes for 10 ounces total.
