Weller - Heavy Duty 80 Watt Soldering Iron with LED Halo Ring, 120V, 880F
Product ID ama-WLIR8012A
In Stock 3
Price: $34.95
Weller - Heavy Duty 80 Watt Soldering Iron with LED Halo Light Ring, 120V, 880 F
If your soldering 8 and 10 gauge wire with, 5.5, 6.0 or 8mm connectors, this is an absolute must. The large, high watt iron has a large tip that holds enough heat to solder the larger wire and bullets without cooling down and leaving you with a cold solder joint.
Features:
High-Performance LED Soldering Iron - 80 Watts, up to 8800-Degree F.
Spektrum Soldering Jig
1 of 4
Product ID hh-spmx-1009
Price$29.99
Hot Racing Plug/Connector Soldering Jig
Product ID hh-sd488E
Price$22.99
Kester Solder 60/40 .040 DIA. 1LB SPOOL
1 of 2
Product ID ama-kester-ser44-040
Price$59.99
