Scale Outboard with Metal Lower Unit: All Black
Product ID bel-2041-alu
In Stock 8
Price: $199.99
Scale Outboard.
Features a completely metal lower unit, including steel gears, for enhanced durability.
Includes: Everything in the picture.
Specs:
Length: 138mm (5.43")
Width: 47mm (1.85")
Height: 170mm (6.69")
Weight: 204.12 (7.2 Oz)
Shaft: 3.175mm (1/8")
Requires:
Motor with 5mm diameter shaft and 19mm motor hole mounting spacing. Suggested Motor flh-d3548.
Prop for 1/8" shaft, this unit will fit up to a 40mm diameter propeller.
Steering linkage, hh-817, 4-40 rod, and OSE-83106.
Notes: This is designed for scale boats in the 25" (650mm) to 35" (900mm) length range and 3-5 pounds total weight. The manufacturer suggests a flh-d3548-41100 motor on 3s to 5s. If your boat falls within those specs, we suggest a 90amp or greater.
Click for Instructions and a Diagram
1 Product Reviews - Average rating 5 / 5 (Show All)
Works Well, No complaints
G30 Blue - 26th October 2022
My Daughter and I built the G30 Tunnel Hull from Zipp Kits. My daughter is 11 years old. She wanted a motor that looks like a real motor, so we chose this one. She loved the Evinrude Decals. We were then told that this motor would be too slow for the read more
3548 Brushless Outrunner Motor 35mm x 48mm
1 of 2
Product ID flh-d3548
Price$24.95
4-40 Linkage Rod (2.4mm diameter)
1 of 2
Product ID hh-4-40-3753
Price$1.99
OSE Raider 6s 90amp Esc with Ec5 connectors
1 of 2
Product ID ose-R-90
Price$49.99
One 1992.1 gear for bel-2041 Outboard
Product ID bel-1992-1-gear
Price$19.99
One 1992.3 gear for bel-2041 Outboard
Product ID bel-1992-3-gear
Price$19.99
Linkage Rod Connector for 4-40 Rod
1 of 2
Product ID ose-83106
Price$2.49
Du-Bro Safety Lock Kwik Link for 4-40 Pushrod
1 of 2
Product ID hh-817
Price$3.49
