High performance Sevan Outboard
Product ID bel-flex-2042
Price: $169.99
High-performance Sevan Drive with adjustable aluminum transom bracket, built for high performance with the scale look. These come in 3 different color schemes, all with a metal lower unit. Designed and manufactured in Europe.
We categorized this as a drive, instead of an outboard, because the motor is not contained within the outboard. When you install this unit in your hull, you will mount your motor inside of the hull. Then the flex cable is run in a traditional stuffing tube and run into the front of the drives bullet (see picture 3). The flex cable will have less strain and be able to spin at high rpm than most rc outboards on the market.
Available in three color schemes. See picture 2.
-Grey Cowl with Black lower
-Red Cowl with black lower
-Grey Cowl with Silver lower
Specs:
Length: 110mm (4.33"), not including bracket
Width of servo arms: 55mm (2.16")
Width of outboard cover: 52mm (2.05")
Height: 165mm (6.50")
Weight: 182g (6.4 oz)
Prop size: Will fit up to 44mm diameter prop. Which exact prop will depend on setup.
Mounting Bracket: 35mm wide x 30mm tall
Shaft: For 3/16" diameter propellers
Includes:
Everything in picture one.
Requires:
.187 (4.76mm) Flex cable and it to be glued into the prop shaft.
For info on how to do that, click here.
Propeller: 3/16" (4.75mm) shaft, We recommend the cnc series.
Prop nut: 4mm threads.
Hull: Recommended setup for a 30" (760mm) to 35" (900mm) length boat in the 3-5 pounds total weight range.
Motor: 3650 to 4074 sized brushless motor.
K&S Stuffing Tube: 8132
Teflon: .187 Size
Operation Instructions: This item ships without oil in the case. it is necessary to fill the case with a oil similar to 75W90. We suggest replacing the oil after each days use.
1 Product Reviews - Average rating 4 / 5 (Show All)
Scale outboard
Joseph Long - 17th March 2025
Very nice and awesome looking outboard. Hatches come off if it flips. Must at foam inside to save and there's no replacement parts
Durable lower units though.
Quicksilver Premium Gear Lube SAE 80W-90 : Sale Normally $15.99
Product ID ama-802844Q02
Price$12.99
Octura .187 cable, 24" long : Black
Product ID oct-oc187L-24a
Price$5.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
K&S Brass Tubing 36" long (915mm)
1 of 4
Product ID ks-brass-tb-36
Price$7.99
Teflon Liner 24" (600mm)
Product ID oct-teflon-24
Price$4.49
Retaining Glue Loctite 638
Product ID mc-loc638
Price$24.99
