6mm Thrust Bearing
Product ID boc-f6-14g
In Stock 1
Price: $8.99
This bearing will reduce motor heat by removing the pressure from the rear motor housing bearing in a brushed or brushless motor.
 This will fit most motors with a 6mm output shaft, including the KB Motor Series.
Measures:
6mm id x 14mm od x 5mm wide
