Factory Refurbished, Save $169.99 : Seal G2 Series ESC : 300A OPTO 6s-14s
Product ID clr-ztw-300-7300410-v2
In Stock 0
List Price: $329.99
Price: $159.99
Factory Refurbished, normally $329.99. Now only $159.99
ZTW SEAL G2 Series 300 v2 : OPTO 6s-14s : 300 amps : Lipo Brushless ESC.
Following up on the success of the ZTW 300, ZTW has released a 32-bit version of the Seal 300. The Seal G2 comes in a new compact design that is 100 grams lighter, shorter, and narrower than its predecessor.
The 32-bit Microcontroller supports the "CAN protocol" for recording data. The ESC can be programmed via the optional LCD prog card or the mobile phone app (requires additional Bluetooth), and it supports real-time data. More info will be coming.
The ZTW SEAL G2 Series is designed specifically for RC Boat applications and features a waterproof design. The 300A ESC includes two water-cooling pipes and customized heat sinks. However, the 300A ESC lacks a built-in BEC, so an additional battery pack is required to power the servo. To protect the boat, the ESC offers a power reduction when it is too hot and an optional Low Voltage Cutoff. For more specific information, see the specs below...
Specs:
The waterproof design (rated IP67) allows this ESC to operate in wet conditions.
Continuous Current (A): 300 Amps
Burst Current(A): XXX Amps
Voltage: 6s - 14s Lipo (18-42 NiMH)
Power Wire: 8 Gauge160mm-Red/160mm-Black
Motor Wire 8 Gauge 160mm-Black
Battery Eliminator Circuit (BEC): None, requires RX pack or BEC Eliminator Circuit.
The throttle works in both forward and reverse, or you can lock out the reverse function for racing safety.
Optional programming with LCD programming card.
Case dimensions (not including wires):
Length: 130mm (5.12")
Width: 65mm (2.56")
Height: 38mm (1.50")
Weight: 530g
Water fitting thread size: M6
Includes: Everything in picture number one
Requires: Connectors, 8mm bullet connectors or larger.
Note: This ESC requires an optional receiver battery pack or an external BEC circuit. This ESC was designed to operate in an environment where it may occasionally get wet. Not for use underwater. OSE does not suggest using this item underwater!! This ESC is recommended for boats in the 40" (1000mm) plus range. Because there are so many variables with each hull and installation, it's impossible to specify all the applications for this ESC. If you have any questions about using this ESC with your particular boat, don't hesitate to get in touch with us before purchasing.
