CNC 32mm Aluminum prop for 4mm prop shaft
Product ID cnc-3214251-4mm
In Stock 5
Price: $15.95
CNC 3214 Magnalium 7075 propeller, 32mm Diameter
This propeller fits 4mm smooth shafts that have a drive dog and is held on by a nut.
Machine cut to high tolerances makes this prop ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
Specs:
32mm diameter
1.4 pitch ratio
1.76" (44.7mm) total pitch
CNC 34mm Aluminum prop for 4mm prop shaft
Product ID cnc-3414251-4mm
Price$15.95
CNC 34mm 3 Blade Aluminum prop for 4mm prop shaft
Product ID cnc-o3414351-4mm
Price$21.99
CNC 36mm 3 Blade Aluminum prop for 4mm prop shaft
Product ID cnc-o3614351-4mm
Price$21.99
TFL Mini Scale Outboard
1 of 4
Product ID tfl-B54217b
Price$139.99
