CNC Prop 32mm 3 BLD - 1/8" bore
Product ID cnc-3214350
In Stock 0
Price: $15.95
CNC 3214 3 Blade Magnalium 7075 propeller.
Machine cut to high tolerances makes this prop ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
Left-hand rotation. These spin counterclockwise when looking at them from the back of the boat.
Fits 1/8"(.125" 3.17mm) Smooth Bore Propeller Shafts.
DiameterTotal Pitch
32mm (1.26")1.76"
NOTE for Traxxas Blast:
Requires Octura oct-ocgcss4 upgrade shaft to fit onto Traxxas Blast. Larger props will also require closer monitoring of motor and ESC heat.
« Previous | Next »
Octura 1/8" prop shaft upgrade for the Traxxas Blast
1 of 2
Product ID oct-ocgcss4
Price$8.75
