CNC Prop 32mm 3 BLD - 1/8" bore, high pitch
Product ID cnc-3218350
In Stock 8
Price: $15.95
CNC 3218 3 Blade Magnalium 7075 propeller. Higher pitch than the cnc-3214250
Machine cut to high tolerances makes this prop ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
Left-hand rotation. These spin counterclockwise when looking at them from the back of the boat.
Fits 1/8"(.125" 3.17mm) Smooth Bore Propeller Shafts.
DiameterTotal Pitch
32mm (1.26")2.26"
NOTE for Traxxas Blast:
Requires Octura oct-ocgcss4 upgrade shaft to fit onto Traxxas Blast. Larger props will also require closer monitoring of motor and ESC heat.
