CNC Prop 38mm - 4mm bore, high pitch
Product ID cnc-3819250-4mm
In Stock 7
Price: $19.95
CNC 3819 Magnalium 7075 propeller. 1.9" Pitch Ratio. Higher pitch than the cnc-3814250. Designed for use on 4mm prop shafts.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
CNC 7512 Magnalium Propeller Size Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
3819250-4mm
38mm (1.5")71.82.83"4mm
Specifications:
  • Pitch ratio: 1.9
  • Blades: 2
  • Material: CNC Machined Magnalium 7075.
  • Mounting & Shaft Size: 4mm Drive dog.
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
TFL lower unit parts for the TFL scale outboard pn# tfl-b54210
1 of 2
Product ID tfl-b54210-H
Price$79.99
