CNC Prop 48mm 3 BLD Reversed - Pointed Tip - 3/16 bore
Product ID cnc-4814350-R
In Stock 10
Price: $24.95
CNC 4814350-R Reversed 3 Blade - Pointed tip - Magnalium 7075 propeller.
Machine cut to high tolerances makes this prop ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
ATTENTION: Right and rotation. These spin clockwise when looking at them from the back of the boat. Used for twins or boats that require opposite rotation than normal.
Fits 3/16"(.187" 4.76mm) Smooth Bore Propeller Shafts.
Diameter Total Pitch
48mm (1.89") 2.65"
CNC Prop 48mm 3 BLD - Pointed Tip - 3/16 bore
Price$24.95
