CNC 6717 Magnalium 7075 propeller. Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
Specifications:
Pitch ratio: 1.7
Blades: 4
Material: Magnalium 7075 with Hard oxygen-anodized coating for added strength.
Mounting: 1/4" Drive dog, depending on propeller size.
Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
