CNC Aluminum Prop 67mm, 4 BLD Reversed - 1/4 bore : Hardened : Reversed
Product ID cnc-6717451-H-rev
In Stock 3
Price: $49.99
CNC Aluminum 6717451-R Reversed  4 Blade Magnalium 7075 propeller. Hardened for strength.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
ATTENTION: Right and rotation. These spin clockwise when viewed from the back of the boat. Used for twins or boats that require opposite rotation than normal. See picture.
Fits 1/4"(.250" 6.35mm) Smooth Bore Propeller Shafts.
DiameterTotal Pitch
67mm (2.64")4.48"
