CNC Brass Prop 67mm, 4 BLD - 1/4 bore
Product ID cnc-6717461
In Stock 5
Price: $54.99
CNC 6717 Brass, 4 Blade propeller.
Machine-cut to high tolerances, this prop is ready to use right out of the box.
CNC 6717 Brass Propeller Size Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-6717451
67mm (2.64")113.84.481/4"
Specifications:
  • Pitch ratio: 1.7
  • Blades: 4
  • Material: Brass
  • Mounting:  1/4" Drive dog, depending on propeller size.
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
« Previous | Next »
CNC Aluminum Prop 67mm, 4 BLD - 1/4 bore : Hardened
1 of 3
Product ID cnc-6717451-H
Price$49.99
CNC Prop 67mm 3 BLD - 1/4 bore
Product ID cnc-6717352
Price$39.95
