CNC Prop 74mm, 3 BLD - 1/4 bore
Product ID cnc-7414352
In Stock 2
Price: $39.95
CNC 7414 Magnalium 7075 propeller.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
CNC 7512 Magnalium Propeller Size Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-741435274 mm (2.91")103.64.081/4"
Specifications:
  • Pitch ratio: 1.4
  • Blades: 3
  • Material: CNC Machined Magnalium 7075.
  • Mounting & Shaft Size: 1/4" (6.35mm) Drive dog.
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
« Previous | Next »
