OSE CNC High Rake Series Props : Reverse Rotation : Brass & Iron alloy : 40 to 52mm Diameter Options
Product ID cnc-H-series-R
List Price: $49.99
Price: $39.99
OSE H Series Cleaver, reverse rotation, 2 Blade Propellers, machined from a brass alloy containing copper, zinc, & iron.
CNC-machined to high tolerances for out-of-the-box use. No modifications are needed. Due to the strong alloy used in these props, the leading edge is machined to a sharp edge for maximum performance.
OSE CNC High Rake 1.6 Pitch Propeller Size Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-H-4016-R40 mm (1.57")64.02.523/16"
cnc-H-4216-R42 mm (1.65")67.22.653/16"
cnc-H-4416-R44 mm (1.73")70.42.773/16"
cnc-H-4616-R46 mm (1.81")73.62.903/16"
cnc-H-4816-R48 mm (1.89")76.83.023/16"
cnc-H-5016-R50 mm (1.97")80.03.153/16"
cnc-H-5216-R52 mm (2.05")83.23.283/16"
cnc-H-5416-R54 mm (2.13")86.43.403/16"
Specifications:
  • Pitch ratio: 1.6
  • Blades: 2
  • Material: Brass alloy containing copper, zinc, & iron
  • Mounting: Drive dog
  • Rotation: Clockwise. ATTENTION: This is a right-hand rotation prop. These spin clockwise when viewed from the back of the boat. These are often used for twins or boats that require opposite rotation than normal. See picture 1 to view the prop's rotation.
Notes: For the TFL-1133-cf-4082 Zonda, we suggest the 42mm props for oval running and 44mm props for high-end speed for a few seconds.
OSE CNC High Rake Series Props : Brass & Iron alloy : 40mm to 52mm Diameter Options
1 of 4
Price$39.99
