CNC De-Tongued Aluminum Series Props : 40 to 70mm
Product ID cnc-dt-xx16
Price: $19.95
CNC De-Tongued Aluminum Series Props in 1.6 Pitch Ratio.
This prop has less blade in the tongue area, which allows for a bit higher rpm for more top speed. But a bit less take-off out of the hole.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
CNC De-Tongued Aluminum Propeller Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-dt-4016-D40 mm (1.57")63.752.51"3/16"
cnc-dt-4216-D42 mm (1.65")67.312.65"3/16"
cnc-dt-4416-D44 mm (1.73")70.352.77"3/16"
cnc-dt-4616-D46 mm (1.81")73.662.90"3/16"
cnc-dt-4717-D47 mm (1.85")80.003.15"3/16"
cnc-dt-4816-D48 mm (1.89")76.703.02"3/16"
cnc-dt-5016-D50 mm (1.97")80.003.15"3/16"
cnc-dt-5216-D52 mm (2.05")83.313.28"3/16"
cnc-dt-701625270 mm (2.76")112.274.42"1/4"
Specifications:
  • Pitch ratio: itch ratio: All are 1.6, except the 4717, which is a 1.7 pitch ratio.
  • Blades: 2
  • Material:  Magnalium 7075 alloy
  • Mounting: Drive dog
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
« Previous | Next »
CNC De-Tongued Aluminum Series Props : Reversed Rotation : 40 to 52mm
1 of 3
Product ID cnc-dt-xx16-R
Price$19.95
Recently Viewed
Pick up where you left off.
