CNC De-Tongued Aluminum Series Props : Reversed Rotation : 40 to 52mm
Product ID cnc-dt-xx16-R
Price: $19.95
Reverse-Rotation CNC De-Tongued Aluminum Series Props at 1.6 Pitch Ratio.
This prop has fewer blades in the tongue area, allowing for a slightly higher RPM for increased top speed. But a bit less take-off out of the hole.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
 CNC De-Tongued Aluminum Propellers - Reverse Rotation
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-dt-4016-D-rev40 mm (1.57")63.752.51"3/16"
cnc-dt-4216-D-rev42 mm (1.65")67.312.65"3/16"
cnc-dt-4416-D-rev44 mm (1.73")70.352.77"3/16"
cnc-dt-4616-D-rev46 mm (1.81")73.662.90"3/16"
cnc-dt-4717-D-rev47 mm (1.85")80.003.15"3/16"
cnc-dt-4816-D-rev48 mm (1.89")76.703.02"3/16"
cnc-dt-5016-D-rev50 mm (1.97")80.003.15"3/16"
cnc-dt-5216-D-rev52 mm (2.05")83.313.28"3/16"
 Specifications:
  • Pitch ratio: All are 1.6, except the 4717, which is a 1.7 pitch ratio.
  • Blades: 2
  • Material:  Magnalium 7075 alloy
  • Mounting: Drive dog
  • Rotation: Clockwise. ATTENTION: This is a right-hand rotation prop. These spin clockwise when viewed from the back of the boat. These are often used for twins or boats that require opposite rotation than normal. See picture 1 to view the prop's rotation.
« Previous | Next »
CNC De-Tongued Aluminum Series Props : 40 to 70mm
1 of 3
Price$19.95
