CNC De-Tongued Brass Series Prop : 44 to 52mm
Product ID cnc-dt-xx16-br
Price: $29.99
CNC De-Tongued Brass Series Props in 1.6 Pitch Ratio.
This prop has less blade in the tongue area, which allows for a bit higher rpm for more top speed. But a bit less take-off out of the hole.
Machine-cut to high tolerances, this prop is ready to use right out of the box. Machined out of a brass alloy containing copper, zinc, & iron.
CNC De-Tongued Brass Propeller Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-dt-4416-D-BR44 mm (1.73")70.352.77"3/16"
cnc-dt-4816-D-BR48 mm (1.89")76.703.02"3/16"
cnc-dt-5216-D-BR52 mm (2.05")83.313.28"3/16"
Specifications:
  • Pitch ratio: All 1.6, except 4717, which is 1.7
  • Blades: 2
  • Material:  Brass alloy containing copper, zinc, and iron
  • Mounting: Drive dog
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
« Previous | Next »
