CNC De-Tongued Aluminum Series Props : 40mm-52mm Diameter : Reversed
Product ID cnc-dt-xx16-rev
Price: $19.95
Reverse Rotation, CNC De-Tongued Aluminum Series Props in 1.6 Pitch Ratio.
Size options from 42mm to 52mm diameter, see picture 3 for specs.
This prop has fewer blades in the tongue area, allowing for a slightly higher RPM for increased top speed. But a bit less take off out of the hole.
Machine-cut to high tolerances makes this prop ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
 ATTENTION: Right rotation. These spin clockwise when viewed from the back of the boat. Used for twins or boats that require opposite rotation from normal.
« Previous | Next »
CNC De-Tongued Aluminum Series Props : 40mm-70mm Diameter
1 of 3
Price$19.95
