Reversed Magnalium 7075 propeller. Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
Specifications:
Pitch ratio: All 1.4
Blades: 2
Material: Magnalium 7075 alloy
Mounting: Drive dog
Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
ATTENTION: This is a right-hand rotation prop. These spin clockwise when viewed from the back of the boat. These are often used for twins or boats that require opposite rotation than normal. See picture 1 to view the prop's rotation.
